Syntax Highlighting for a set of numbers
    Jun 13, 2006#1
    im new here and hope to find a resolution for this problem:
    I want to highlight only a set of numbers in red:
    for instant the line of numbers:
    0419C00000000500000000033293011100000000000002001
    and i want to highlight:
    419C and 332930 automatically.
    everybody may help me?
    THX
    LL
    6,677585
      Jun 13, 2006#2
      UltraEdits' syntax highlighting highlights words.
      0419C00000000500000000033293011100000000000002001 is 1 word as long as you do not specify for example the 0 character as delimiter.
      /Delimiters = 0
      /C1"Numbers"
      33293
      419C
      You can not highlight 332930 because 0 is a delimiter and so 332930 is word "33293" and word "0". It's not possible to highlight only a part of a word. You could use a macro which inserts for example a space before and after every interesting number in the number stream for syntax highlighting.
        Jun 13, 2006#3
        thanks a lot!!!!
