Wordfile.txt - Automatic refresh
    Jul 26, 2006#1
    Hello everyone,
    I try to automatically modify the wordlist by a python script. This works fine but needs a restart of UEdit for taking the changes into account.
    Is there a way to perform an auto refresh while Uedit is active?
    Cheers,
    Spark
    6,683583
      Jul 27, 2006#2
      UltraEdit does not detect changes in the wordfile which are done outside UltraEdit. But it automatically rereads the wordfile if the changes are done within current instance of UltraEdit.
      So after you have modified your wordfile with the Python script, you have to open your modified wordfile in UltraEdit, make a temporary modification (insert a space and delete it immediately with backspace) and save it and close the wordfile. Assuming you run the Python script via an UltraEdit user tool, the following macro would do this:
      RunTool "Case sensitive name of the python script running tool"
      Open "Name of your wordfile with full path"
      Key BACKSPACE
      CloseFile Save
      Disadvantage of this solution: the wordfile will be added to the list of recently used files.
        Jul 27, 2006#3
        Succeeded!
        THX Spark
