I've prepared the wordfile.txt file especially for the ActionScript language.
I used to select the php language to work because it's similar for many functions ... but rarely for the properties.
So after few hours, I have set up something which is not perfect but which would suit not too bad, because I have collected many datas from the help of flash, I have dispatched the words in different groups, sorted them according to what UE expect, be careful with duplicates ...
I thought it should be ok, but it doesn't work for many words and I don't know what's happening, of course !
So this is the interesting part of the file and I hope you will let me know if you have improved it ( no attachment possible ... )
I use the 12.00 version
I can join you the lists in separated files with each word on one line, if you don't know how to split the lists (I don't personnaly !)
/L12"ActionScript" Nocase HTML_LANG Line Comment = // Line Comment Alt = # Block Comment On = /* Block Comment Off = */ Block Comment On Alt = <!-- Block Comment Off Alt = --> Escape Char = \ String Chars = "' File Extensions = AS
/Delimiters = ~!@%^&*()+-=|\{}[]:;"'<> , .?_
/Function String = "%[^t ]++function[^t ]+^([a-zA-Z0-9_&]+*^){"
/Function String 1 = "%[^t ]++function[^t ]+^([a-zA-Z0-9_&]+*^)^p*{"
/Indent Strings = "{"
/Unindent Strings = "}"
/C1"Bibs" STYLE_TAG
accessibility behaviors containers controls core data effects events lang managers mx screens services skins styles
transitions utils video xpath
/C2"Properties" STYLE_ATTRIBUTE
UTC VPixels __proto__ __resolve _accProps _alpha _currentframe _droptarget _focusrect _framesloaded _global _height
_highquality _level _listeners _lockroot _name _parent _quality _root _rotation _soundbuftime _target _totalframes _url
_visible _width _x _xmouse _xscale _y _ymouse _yscale a accName actionScript activeEffect activityLevel aliasText align
alignment allowSmoothing alpha alphaMultiplier alphaOffset alphas angle antiAliasSharpness antiAliasThickness antiAliasType
attributes autoExpand autoKern autoLabel autoReplace autoSize avHardwareDisable available b background backgroundColor
bandwidth bias bitRate bits blendMode blockIndent blueMultiplier blueOffset blurX blurY bold border borderColor bottom
bottomRight bottomScroll breakAtCorners brightness bufferLength bufferTime builtInItems bullet buttonTracking bytesLoaded
bytesTotal c cacheAsBitmap callee caller capType caption category characterPosition characterSpacing characters childNodes
childScreens clamp color colorAlphaAmount colorAlphaPercent colorArray colorBlueAmount colorBluePercent colorGreenAmount
colorGreenPercent colorMode colorRedAmount colorRedPercent colorTransform colors componentX componentY componentsPanel
compressionType concatenatedColorTransform concatenatedMatrix condenseWhite configDirectory configURI constructor
contactSensitiveSelection contentType contours contrast convertStereoToMono createNewDocList createNewDocListType
createNewTemplateList creationDate creator currentFps currentFrame currentLayer currentPublishProfile currentScreen
currentTimeline curve customItems d dash1 dash2 deblocking defaultItem density depth description display displayName distance
divisor docTypeDecl documents dotSize dotSpace drawingLayer duration edges effectName elementType elements embedFonts
embedRanges embeddedCharacters enabled exactSettings face fileList fillColor filters firstChild firstFrame focalPoint
focusEnabled font fontFamily fontRenderingMode fontSize fontStyle fontWeight forceSimple fps frameCount frameRate frames gain
getDate getDay getFullYear getHours getMilliseconds getMinutes getMonth getSeconds getTime getTimezoneOffset getUTCDate
getUTCDay getUTCFullYear getUTCHours getUTCMilliseconds getUTCMinutes getUTCMonth getUTCSeconds getUTCYear getYear
greenMultiplier greenOffset gridFitType groupName hPixels hasAccessibility hasAudio hasAudioEncoder hasCustomEase
hasEmbeddedVideo hasIME hasMP3 hasPrinting hasScreenBroadcast hasScreenPlayback hasStreamingAudio hasStreamingVideo
hasVideoEncoder hatchThickness height hidden hideObject highlightAlpha highlightColor hitArea hscroll html htmlText hue
iconID id id3 idMap ignoreWhite indent index inner instanceName instanceType interior isDebugger isDrawingObject isGroup
isLine isMissing italic itemType itemURI items jiggle joinType kerning knockout labelType language languageCodeArray
lastChild layer layerCount layerType layers leading left leftMargin length letterSpacing library libraryItem lineSpacing
lineType linearRGB linkageClassName linkageExportForAS linkageExportForRS linkageExportInFirstFrame linkageIdentifier
linkageImportForRS linkageURL list listIndex livePreview loaded localFileReadDisable localName locked loop manufacturer
mapBitmap mapPoint marginLeft marginRight matrix matrix matrixX matrixY maxCharacters maxChars maxLevel maxhscroll maxscroll
menu message miterLimit mode modificationDate motionLevel motionTimeOut motionTweenOrientToPath motionTweenRotate
motionTweenRotateTimes motionTweenScale motionTweenSnap motionTweenSync mouseWheelEnabled mruRecentFileList
mruRecentFileListType multiline muted name names namespaceURI nextScreen nextSibling nodeName nodeType nodeValue
objectDrawingMode opaqueBackground orientation os outline outputPanel overflow pageHeight pageWidth paperHeight paperWidth
parameters parentLayer parentNode parentScreen password path pattern pixelAspectRatio pixelBounds playerType posArray
position prefix preserveAlpha prevScreen previousSibling projectURI prototype publishProfile publishProfiles quality rate
ratios rectangle redMultiplier redOffset reload renderAsHTML restrict rgb right rightMargin rootScreen rotation sampleRate
sandboxType saturation scale9Grid scaleMode scaleType scaleX scaleY scalingGrid scalingGridRect screenColor screenDPI
screenOutline screenResolutionX screenResolutionY scrollRect scrollable selectable selected selection selectionEnd
selectionStart separatorBefore serverString setDate setFullYear setHours setMilliseconds setMinutes setMonth setSeconds
setTime setUTCDate setUTCFullYear setUTCHours setUTCMilliseconds setUTCMinutes setUTCMonth setUTCSeconds setYear shadowAlpha
shadowColor shapeFill shapeTweenBlend sharpness shortcut showMenu silenceLevel silenceTimeOut silent size size smoothing
soundEffect soundLibraryItem soundLoop soundLoopMode soundName soundSync sourceAutoUpdate sourceFile sourceFilePath
sourceLibraryName space startFrame status strength stringIDArray strokeHinting style styleSheet symbolType tabChildren
tabEnabled tabIndex tabStops target text textAlign textAttrs textColor textDecoration textHeight textIndent textRuns textType
textWidth thickness time timeline timelines tools top topLeft trackAsMenu transform transparent tweenEasing tweenType tx ty
type underline url useCodepage useDeviceFonts useEchoSuppression useHandCursor useImportedJPEGQuality useImportedMP3Quality
useSingleEaseCurve useXMLToUI value valueType variable variableName variation verbose version vertices videoType viewMatrix
visible waveHeight waveLength width wordWrap xmlDecl xmlui y zoomFactor
/C3"Components" STYLE_STATEMENT
#include Accordion Alert Array Boolean Button Camera CellRenderer CheckBox Collection Color ComboBox ComponentMixins
ContextMenu ContextMenuItem CustomActions CustomFormatter CustomValidator DataGrid DataGridColumn DataHolder DataProvider
DataSet DataType Date DateChooser DateField Delta DeltaItem DeltaPacket DepthManager EndPoint Error EventDispatcher
FLVPlayback FocusManager Form Function Interface Iterator Key Label List LoadVars Loader LocalConnection Log Media
MediaController MediaPlayback Menu MenuBar MenuDataProvider Microphone Mouse MovieClip MovieClipLoader NetConnection
NetStream Number NumericStepper Object PendingCall Point PopUpManager PrintJob ProgressBar RDBMSResolver RadioButton
RectBorder SOAPCall Screen ScrollPane Selection SharedObject SimpleButton Slide Sound Stage String StyleManager System
SystemManager TextArea TextField TextFormat TextInput TextSnapshot TransferObject TransitionManager Tree TreeDataProvider
Tween TypedValue UIComponent UIEventDispatcher UIObject UIScrollBar Video WebService WebServiceConnector Window WindowXML XML
XMLConnector XUpdateResolver
/C4"Operators" STYLE_OPERATOR
add
ge
ne
le
new
and
instanceof
void
not
eq
or
lt
gt
/C5"events" STYLE_EXTENSION
Error allowDomain allowInsecureDomain on onActivity onCancel onChanged onClipEvent onClose onComplete onConnect onData
onDragOut onDragOver onEnterFrame onHTTPError onHTTPStatus onID3 onIOError onKeyDown onKeyUp onKillFocus onLoad
onLoadComplete onLoadError onLoadInit onLoadProgress onLoadStart onMetaData onMouseDown onMouseMove onMouseUp onMouseWheel
onOpen onPress onProgress onRelease onReleaseOutside onResize onRollOut onRollOver onScroller onSecurityError onSelect
onSetFocus onSoundComplete onStatus onXML
/C6"Constants" STYLE_KEYWORD
ALPHANUMERIC_FULL ALPHANUMERIC_HALF BACKSPACE CAPSLOCK CASEINSENSITIVE CHINESE CONTROL DELETEKEY DESCENDING DOWN E END ENTER
ESCAPE HOME INSERT JAPANESE_HIRAGANA JAPANESE_KATAKANA_FULL JAPANESE_KATAKANA_HALF KOREAN LEFT LN10 LN2 LOG10E LOG2E
MAX_VALUE MIN_VALUE NEGATIVE_INFINITY NUMERIC NaN PGDN PGUP PI POSITIVE_INFINITY RETURNINDEXEDARRAY RIGHT SHIFT SPACE SQRT1_2
SQRT2 TAB UNIQUESORT UNKNOWN UP true false
/C7"Functions" STYLE_FUNCTION
Accessibility Binding BitmapInstance BitmapItem CompiledClipInstance ComponentInstance Contour Document Edge Effect Element
FLfile Fill Filter Frame Instance Item Layer MMExecute Math Matrix Parameter Path Project ProjectItem ScreenOutline Shape
SoundItem Stroke SymbolInstance SymbolItem Text TextAttrs TextRun Timeline ToolObj Tools Vertex VideoItem XMLUI abstract add
and asfunction break byte case catch catch char chr class clearInterval continue debugger default delete do double dynamic
else elseif enum eq escape eval export extends finally finally flash float folderItem fontItem for fscommand function ge get
getProperty getTimer getURL getVersion goto gt halfEdge if ifFrameLoaded implements import in instanceof int interface
intrinsic isFinite isNaN le loadVariables loadVariablesNum long lt mbchr mblength mbord mbsubstring ne new not on onClipEvent
or ord parseFloat parseInt print printAsBitmap printAsBitmapNum printNum private protected public return set setInterval
setProperty setvariable short showRedrawRegions static super switch synchronized targetPath tellTarget this throw throws
toggleHighQuality trace transient try typeof unescape unloadMovie unloadMovieNum updateAfterEvent var void volatile while with
/C8"Methods" STYLE_METHOD
BitmapData BitmapFilter BlurFilter ColorMatrixFilter ConvolutionFilter Delegate DropShadowFilter FileReference
FileReferenceList GlowFilter GradientBevelFilter Void abs accept acos activeTool addCallback addCubicCurve addCurve addData
addDataToDocument addDataToSelection addDelayedInstance addFile addFilter addItem addItemToDocument addListener
addMotionGuide addNewItem addNewLayer addNewLine addNewOval addNewPublishProfile addNewRectangle addNewScene addPage addPoint
addProperty addRequestHeader addXMLPath allowDomain allowInsecureDomain altIsDown appendChild apply applyFilter asin atan
atan2 attachAudio attachBitmap attachMovie attachSound attachVideo beginBitmapFill beginDraw beginEdit beginFill beginFrame
beginGradientFill broadcastMessage browse browseForFileURL browseForFolderURL call canPublishProject canTestProject cancel
ceil charAt charCodeAt checkXMLStatus clear clearFrames clearKeyframes clone cloneNode close closeAll closeDocument
closeProject colorTransform concat concatMatrix connect constrainPoint contains containsPoint containsRectangle
convertToBlankKeyframes convertToKeyframes copy copyChannel copyFrames copyPixels copyScreenFromFile cos createBox
createDocument createElement createEmptyMovieClip createFolder createGradientBox createMotionTween createProject
createTextField createTextNode ctlIsDown cubicCurveTo curveTo cutFrames decode deleteEdge deleteItem deleteLayer deleteScreen
deltaTransformPoint dispose doConversion domain download draw drawPath duplicateItem duplicateMovieClip duplicateScreen
editItem enableImmediateUpdates enablePIControl endDraw endEdit endFill endFrame equals exists exp expandFolder fileExists
fillRect findDocumentIndex findItemIndex findLayerIndex findProjectItem findText floodFill floor flush fromCharCode
generateFilterRect getAppMemoryInfo getAscii getAttributes getBeginIndex getBits getBounds getBytesLoaded getBytesTotal
getCaretIndex getCode getColorBoundsRect getControl getControlItemElement getConversionMode getCount getCreationDate
getCreationDateObj getCustomEase getData getDefaultLang getDepth getDocumentDOM getEdge getEnabled getEndIndex getFocus
getFontList getFrameProperty getHalfEdge getInstanceAtDepth getItemProperty getItemType getKeyDown getLayerProperty getLocal
getModificationDate getModificationDateObj getNamespaceForPrefix getNewTextFormat getNext getNextHighestDepth
getOppositeHalfEdge getPan getPersistentData getPixel getPixel32 getPrefixForNamespace getPrev getProgress getProject getRGB
getRect getSWFVersion getSelected getSelectedFrames getSelectedItems getSelectedLayers getSelectedScreens getSelectedText
getSize getStyle getStyleNames getText getTextAttr getTextExtent getTextFormat getTextRunInfo getTextSnapshot getTextString
getTransform getVertex getVisible getVolume globalToLocal gotoAndPlay gotoAndStop hasChildNodes hasData hasOwnProperty
hasPersistentData hide hideBuiltInItems hitTest hitTestTextNearPos identity importEmbeddedSWF indexOf inflate inflatePoint
initialize insertBefore insertBlankKeyframe insertFrames insertItem insertKeyframe insertNestedScreen insertScreen install
interpolate intersection intersects invert invertMatrix isAccessible isDown isEmpty isPropertyEnumerable isPrototypeOf
isToggled itemExists join lastIndexOf lineGradientStyle lineStyle lineTo listFolder load loadBitmap loadClip loadLanguageXML
loadMovie loadMovieNum loadPolicyFile loadSound loadString loadStringEx localToGlobal log makeShape mapPlayerURL max merge
min mouseIsDown moveScreen moveTo moveToFolder newContour newFolder newPath nextFrame nextScene noise normalize offset
offsetPoint openDocument openProject openScript paletteMap parseCSS parseXML pasteFrames pause penDownLoc penLoc perlinNoise
pixelDissolve play pointDistance polar pop pow prevFrame prevScene projectcanPublish projectcanTest projectpublish
projecttest publishProject push quit random read registerClass reloadEffects reloadTools remove removeData removeFrames
removeItem removeListener removeMovieClip removeNode removePersistentData removeTextField renameItem renameScreen
reorderLayer replaceSel replaceText reverse reverseFrames revertDocument rotate round runScript save saveAll saveDocument
saveDocumentAs scale scroll seek selectAll selectAllFrames selectItem selectNone send sendAndLoad setActiveWindow
setAdvancedAntialiasingTable setAttributes setBits setBufferTime setClipboard setColor setCompositionString setControl
setControlItemElement setControlItemElements setConversionMode setCurrentScreen setCursor setCustomEase setDefaultLang
setEmpty setEnabled setFocus setFrameProperty setGain setIcon setItemProperty setLayerProperty setLoadCallback setLocation
setMask setMenuString setNewTextFormat setOptionsFile setPI setPan setPersistentData setPixel setPixel32 setRGB setRate
setScreenProperty setSelectColor setSelected setSelectedFrames setSelectedLayers setSelectedScreens setSelection
setSilenceLevel setString setStyle setTextAttr setTextFormat setTextString setToolName setToolTip setTransform
setUseEchoSuppression setVisible setVolume shift shiftIsDown show showIdleMessage showLayerMasking showPIControl showSettings
showTransformHandles sin slice snapPoint sort sortOn splice split splitEdge sqrt start startDrag stop stopAllSounds stopDrag
substr substring subtract swapDepths symbolconvertToCompiledClip symbolexportSWC symbolexportSWF tan testProject threshold
toLowerCase toString toUpperCase toolObjs transform transformPoint translate uninstall union unloadClip unshift unwatch
updateItem upload valueOf watch write
