Hi Michael
Looks like we have two versions:
PL/I - 7/24/2003
PL/I IBM-Visual Age - 02/18/2003
First off you can find wordfiles by going to Downloads, opening submenu Extras and choosing "Wordfiles".
The help file in UE is incredible! Use it!
Basicly download the PL/I file you like best, open Wordfile.txt & append it with L## not used like L15, save it and than load a PL/I program.
What drives the syntax highlighting is the suffix of the file.
so if you used FTP (which is fantastic for IBM MVS and AS400) there is no file suffix so you have to go to pull down menu "View" --> "View As(Hightlighting File Type)" --> PL/I
It can be a pain if you have a ton of programs, another option is if you want to set "PL/I" as your default Syntax Hightlighting" add '*' which is a wild card, which matches anything.
File Extensions = pli cpy inc mac *
Good Luck PL/I
