Windows PowerShell
Windows PowerShell
    Dec 19, 2006#1
    Does anybody have a WORDFILE.TXT file that handles syntax highlighting for Windows PowerShell v1.0
    thanks,
    Mark
      Dec 23, 2006#2
      I came here to ask the same question... though I have to add that this would be a pretty big wordfile. ;)
        Mar 16, 2007#3
        I have one I put together quickly at http://www.loytty.com/monadwordfileforultraeditv1.zip
        It is by no means perfect, but it will hopefully suffice for you, or at least give you enough of a start to make it better.
        I only tried it out on UE v13
        Good luck, Bill
          Apr 05, 2007#4
          I got a message saying that the zip file was corrupt. I checked, and it seems to be OK, but just in case I have put the plain text at http://www.loytty.com/monadwordfile.txt
