Comment Fold Strings - not working
5
    Apr 24, 2007#1
    I'm using 12.10b
    I cannot seem to get Comment Fold Strings working. I've copied and pasted from the syntax.txt file and the help file, but still I cannot get the following to fold:
    #Region
    asdf
    #End Region
    A [-] appears next to the #Region but it refuses to fold.
    I have the following in my wordfile.txt
    /L20"UNIX Shell Scripts" Line Comment = # Escape Char = \ String Chars = "'` File Extensions = sh ksh csh SH KSH CSH
    /Delimiters = ~%^+|\/{}:;"'` , .
    /Function String = "%[a-zA-Z_]*)"
    /Indent Strings = "{" "then" "else" "for" "do" "case" "function"
    /Unindent Strings = "}" "else" "fi" "endif" "done" "esac" "exit" "return"
    /Open Brace Strings = "{" "(" "[" "if" "do" "case"
    /Close Brace Strings = "}" ")" "]" "fi" "done" "esac"
    /Open Fold Strings = "else" "then" "do" "case" "elif"
    /Close Fold Strings = "else" "fi" "done" "esac"
    /Open Comment Fold Strings = "#Region"
    /Close Comment Fold Strings = "#End Region"
    6,683583
      Apr 25, 2007#2
      Remove the # from both fold strings, specify # as delimiter character and it will work (tested with UE v13.00a).
      By the way: File extensions are on Windows file systems not case sensitive. So sh ksh csh OR SH KSH CSH is enough. UE converts internally the extensions always to upper case.
      5
        Apr 25, 2007#3
        Thank you Mofi :)
        So is it a bug in the documentation when it says the following will work:
        6,683583
          Apr 25, 2007#4
          The documentation does not contain the delimiters and comment specifications for this example. So this example works perfect for example for C/C++ when "#Region" and "#End Region" are ANYWHERE inside a C/C++ line or block comment. # is for C/C++ normally not a delimiter.
