How to highlight 'range different to range?
46
    Feb 21, 2005#1
    Hi all,
    I have a word which is either a keyword or an attribute the difference between the two case is if the word is preceded by a space it's a keyword, if it is preceded by a ' its an attribute.
    Does some one know how to make the syntax highlight to correctly handle this case?
    example:
    variable   t : integer range 0 to 127;       -- range is a keyword
    variable   s : std_logic_vector(sign'range); -- range is an attribute
    Thank's,
    Alain
    Never forget: "Above the clouds, The sky is blue and the sun shine"
      Jul 23, 2006#2
      A really not perfect solution would be to highlight 'range with a marker character specification:
      /Marker Characters = "'e"
      /C1"keywords"
      range
      /C2"attributes"
      'e
      But this would work only if the ' character is used only for 'range and nothing else in the whole file.
      The problem here is that there is no other delimiter between sign and 'range. So the ' must be also a delimiter and this makes it impossible to specify 'range as a highlighting "word".
      46
        Aug 02, 2006#3
        Thank's Mofi for this "not perfect solution" I'll try it.
        Regards from Switzerland,
        Alain
