Visual Basic Function List
    Feb 24, 2005#1
    The VB function list does not include functions.
    e.g. Public Sub main() displays fine. But Public Function Pong() as boolean does not diapley. :(
    I am running v11.00a
      Aug 22, 2005#2
      I dont suppose you ever found a solution to this.
      I have found that the regular expression for Function strings is probably incorrect in teh WordFile.txt.
      It is
      /Function String = "%*^{Function^}^{Sub^}*("
      but if I use this regexp in UE itself (with UE regexps turned on) then it only
      finds Subs as well.
      If I modify this (in the wordfile) to
      /Function String = "%*^{Sub^}^{Function^}*("
      then it only finds Functions.
      I cant get the OR UE regexp to work properly and I think the help may be wrong - I use unix regexps usually.
      Can anyone help with a regexp to do the trick
        Aug 22, 2005#3
        OK, I have a solution. In the wordfile, replace the single line:
        by:
        /Function String = "%*^(Sub*^)("
        /Function String 1 = "%*^(Function*^)("
        /Function String 2 = "%*^(Property [LG]et*^)("
        These will also just list the Sub and the name of the sub. If you want the full display then remove the ^( and ^) from each line
        112
        112
          Aug 22, 2005#4
          Doesn't this ONLY work if these words are at the beginning of the line?
          Paolo
            Aug 22, 2005#5
            Thats what the %* is for (the % matches theg beginning of the line, and the * matches any char zero or more times)
            It certainly picks up private and public subs OK
            112
            112
              Aug 22, 2005#6
              Cool! 8)
              (Learn something new every day!)
              Thanx,
              Paolo
