I have two separate instances of UltraEdit set up with different options. My "regular" UE session uses a modified Slate theme. My "special" UE session was initially set up to use a modified Sterling theme. I decided to try a different theme. I downloaded all of the other themes on the IDM resources page. I then added the themes to UE using the Manage Themes dialog. No problems so far.
However when I went to select one of the new themes I found that the drop down window only allows 24 entries, so not all of the new themes are on the list and you can only select a theme that is on the list.
I did a little looking and didn't find this limitation mentioned elsewhere. As far as I can tell, I will have to delete some themes in order to get the rest to show up.
