I have created a project from existing source files. These source files are in a directory structure that mimics the package (namespace in C#) of the source files. So if a file called Util.java has a package of api.company.com, the source file is located in a directory of api\company\com\Util.java. When the file is compiled it is compiled into api\company\com\Util.class under the release directory.
The compile appears to work fine, but building the jar file is having a problem. Here is the output:
The problem is that once the files are compiled into class files they are in a directory structure under my release directory. Since they are in sub-directories, its not able to find .\*.class. When the jar file is built, it should add the directories that were created with javac and that contain the class files.
--------------------Configuration: my-project - Release--------------------
javac -target 1.5 -d .\ -classpath ..\lib\axis.jar;..\lib\jaxrpc.jar;..\lib\saaj.jar;..\lib\wsdl4j-1.5.1.jar; -g:none @my-project.object
Note: Some input files use unchecked or unsafe operations.
Note: Recompile with -Xlint:unchecked for details.
jar cvfm my-project.jar my-project.man @my-project.resource -C .\ *.class
.\*.class : no such file or directory
added manifest
my-project.jar - 0 error(s), 0 warning(s)
